I've had this car posted before,1969 Dart,had it for 9 yrs,s/6 car over to 440,block is a six pack date coded 1971,built 30 over with 10.5 compression,509 cam,906 heads,by percision engniering in simsbury Ct.coated hooker 2" fenderwells, all msd ignition,m-1 intake,850 mighty demon carb.727 trans,3500 stall,reverse pattern valve body,built by dynamic racing in branford,Ct. 8 3/4 rear,4:10 gears,moser axles,auburn posi.ss springs moved inside the framerails,kyb gas shocks,2X3 boxed steel frame connectors welded through the floor,front driveshaft loop,rear dropped cross member,mini tubbed,weld wheels,dragradials on 10x15 rims 7.5" backspace,four wheel disc brakes,willwood 4 piston in front and ssb corp. kit out back,new brake lines,fuel cell and battery in trunk,cut off switch,holley blue pump,8 an braided fuel lines,new drivers floor pan put in,amutuer paint job done by owner,has some defects with blending some areas,some dings now, a small crack in the drivers quater lip,it still turns heads and thumbs up everytime I take it out,front end all new,tubbular upper a arms,s/6 tortion bars.Interior is partailly done because I was going to install a cage but never did.Fiberglass buckets ,rear seat there,new carpet,gauges,B@M floor shifter,grant steering wheel,have all parts for interior and new headliner from year-one.i spent over $22,000,that I can remember,Asking $15,000 or will consider trades,b-bodies or any type of street rod,Gene at 18604906253 or [email protected]. I am located in Connecticut. Thanks for the ad.
