I'm selling my whole fuel injected small block mopar 340 with everything turn key. Its currently in my 1969 dodge dart. I'm going to try and list everything here I go.
Engine has a steel crank, forged 9.5 to 1 pistons, mopar J steel heads with .202 valves just re done, ARP head studs MLS head gaskets, all custom aluminum brackets, aluminum pulleys, polished saden A/C compressor, power master alternator, custom MSD crank trigger, sfi flywheel hi torque starter, sfi fluid damper,
EFI, it's ran on a holley 950 pro ecm with the wide band upgrade and a holley 3 bar MAP sensor. Also has a MSD 6AL box ran on a crank trigger allowing the ecm to completely control the timing curve as the engine builds boost and vacuum. The ac has a input so the engine idles up when engaged and fun runs the ECM runs everything I also will include my small lab top that I use for tuning.
The turbo has custom built headers with a GT45 turbo the waste gate is set at 8psI and the motor runs great on it. I have pictures of the build. The setup has about 1000 miles on it and gets about 17 mpg in my dart. The engine is still in the car and runs great email or text for details. Asking 6000 for everything.
