1969 dodge dart,origanally s/6 car.Has prof. built 440 (6 pack block)509 cam,906 heads,msd pro billet dist. and 6 al , msd wires,coated hooker fenderwells 2", with 2.5 inch exuast w-flowmasters.MP M-1 with 850 mighty demon,k-n air filter,prof. built 727 with 3000 dynamic stall conv.reverse pattern manual,rear is an 83/4" with custom moser axles,auburn posi unit in a 489 case with 4:10 gears,brakes are s.s brake corp.disc on rear,wilwood 4 piston caliper discs up front,new front end componets,with tubular upper a arms,s-s springs moved inside the frame rails with kb shocks all the way around,mini tubbed with 10 gal. fuel cell,battery in trunk,cut off switch,still has s/6 tortion bars,not a problem on the street like some people say they are.bumpers are fiberglass,lift off fiberglass hood with 6" cowl scoop,new brake lines,8an braided fuel lines,holley blue pump.new rubber seals for body,window felt etc...,nice bench seat interior,back seat brand new from year one. Is missing,arm rest,and speed ometer cable is bloked off,tach,oil pressure water and voltage gagues,new carpet with dynomat under it,B&m floor shift,nice dash,I need to install the head liner and trim new from y-one,has weld wheels,5x15 front and 5x 10 with 7.5" backspace in back w/bfg drag radials, nice piant,the heater box and wiper motor/horn are currently out of the car. located in Tolland Ct.spent over $25,000 to build it,asking $17,000 or interesting trades considered.e-mail is [email protected], for more pics or 1-860 490 6253.Gene.Also have a 73 challenger drag car with a ray barton 528" over $40,000 invested would trade both cars and a 18ft. dual axle car trailer electric brakes,with a winch for a dodge viper -No specific year..
