1969 Dodge Dart Western Sport Special
Everything on the car has been gone through and replaced less than 800 miles ago. I am selling it because I am moving up to the Bay area and can't take it with me. All it needs is paint and some door panels on the inside and it would be completely re done.
The Transmission has a small drop leak around the reverse detent ball. I have tried to fix it with no luck. 40 year old transmission its bound to happen
The Rear end has a small leak as well.
Most everything you see that looks like rust is either the base layer (red) under the original paint or surface rust. This car was originally a vinyl top and I took it off because I didn't want it to hold any moisture in it and rust the roof.
The only bad rust spot is on the pass side quarter. I took a picture of it so you can see it. Its not bad at all.
I have a book of all the receipts for everything that will come with the car.
Has had insurance on it since it was done with an agreed value of $15,000
Please ask any questions you may have. The car is located in Placentia California and I can schedule time to see it if needed.
Please note the car will be listed on other sites as well so I reserve the right to end the listing at any time.
$14,000 OBO. Everything is new except the paint and the drivers door panels.
thank you
Justin
[Phone number removed by staff] Sometimes it is easiest to reach me via text
- Engine 1973 340 Rebuilt with less than 800 miles
- Engine was internally balanced when built
- Heads are the larger valve 2.02 heads
- MSD 6AL Ignition with MSD Distributor
- NEW RPM Air Gap intake with Holley 750 Vac Sec Carb
- Camshaft, Hydraulic Flat Tappet, Advertised Duration 268/276, Lift .464/.464,
- Keith Black Pistons with Eagle Rods
- Had it professionally broken in and dyno'd when it was built 340HP/370TQ @ Indio Motor Machine with Brian
- Transmission All Rebuilt 1966 A833 4 Speed with Hurst Shifter with Pistol Grip. Hydraulic Centerforce Clutch
- All Rebuilt Rear End 8 3/4 with 3.55 Gears and 489 Case
- New 26" Aluminum Radiator with Electric Fan. Does not get hot. Runs cool all day
- Front Brakes have been converted to Disc with all original Parts. New Master Cylinder
- Rear Brakes have been completely replaced
- All New Brake Lines throughout
- New Fuel Tank and Fuel Lines
- Painless Wiring harness throughout the entire car
- New Suspension Torsion bars and shocks in the rear.
- Magnaflow Dual Exhaust
- New Stewart Warner Gauges on the inside
- Alpine CD Player with all new speakers
- New Dash Cap
- New Carpet and Front seat has Legendary new cover on it.
- New Battery Replaced in November 2017
- New Steering Column
- Wheels 2 of the Cragers were bought new the other two were bought lightly used.
- BFG Tires less than 800 miles on them
- The Green Paint is all original except for Drivers Door it had been replaced before I got it
- Power steering
thank you
Justin
