skep419
5.9 Magnum 4 speed afficionado
440source flywheel is on the way. We'll see how it balances out. I have the QuickTime to-531 balance weight that I tried to use with my stock 340 flywheel. I guess it wobbled on the machine.
sent these pics to brewers. Going to have to tear into the trans to see whats all needed. should be a fun learning experience.
you only live once. Going to be using some other parts I had laying around.
I prefer the bushing if the crank is drilled for it. But if it isn't drilled the bearing that slides into the torque converter register will do just fine. If your crank isn't drilled deep enough you will have to cut an inch or so off the input shaft.
It would be greatly appreciated. Also note that it was measured from the top of the hole. Not the hub flange.
