belmateo
Progress is sweet, looking good Rob. Are you going to use the motor that came with the car or you have other plans?
WoooooooooooHoooooooooooo!
Happy Birthday Rob!
I got my tires mounted on my wheels today. Fronts are 215-45-17 and rears are 235-45-17, on 17x7" SBP rims. I have to switch over to right hand studs on the passenger side to get them to fit. I just ordered the studs.
What is the offset or backspacing on your Wheels Rob?
How's was your B-day Rob? Have you looked at the Pro Max set up for the six pack? http://promaxcarbs.bizland.com/id1.html
I tell you mine idle so smooth it's like I've got a 4 bbl. I might be up in Santa Rafael next weekend with the Dart,
I'll give you a call and maybe we can go out for a run.
I got the Billet Jet Plates,Billet throttle base and the Six Pack Metering Block. It makes tuning so much easier and you don't have to remove the rear carb to adjust the idle mixture screws so you can do it while the engine is running.
Go for it Rob, sorry to hear about the garage falling through. Hang in there buddy.
Sounds like a cool idea-I wish you the best of luck for your business. It does suck that your garage idea fell through, but perhaps it was a blessing in disguise...
