Semeincha
Kenosha WI. 53143 Asking $15,000 as a package..Read below.
1969 Dodge Dart w/1970 Dart Swinger Front
I have owned this car for 32 years. Purchased in Mountain Home AFB Idaho.
I have stripped this car and restified it.From 1987-2001 when it was completed.
Lone gone is the original 273 engine and 904 tranny along with the 7 ¼ rear, drum brakes and weak rear springs.
Stock 1968 318 motor from 1968 Dodge Coronet 440. Pulleys Poder coated
Heads refreshed 2013 light exhaust port cleanup and intake port matching done
Fuel: Carter Thermo-quad 800CFM Carburetor
Fuel Pump: Carter super pump
Manifold: Edelbrock RPM Air Gap
TTI Headers and Full exhaust with Flowmaster Series 40 mufflers and NOS Tips yes you can see the difference from cheap tips.
Mopar mini-starter
Front K-Member – Powder Coated
8 ¾ Sure Grip 3:23.1 Ratio Housing and Backing plates Powder coated 10x2.5 inch Drums (Original Bendix), Green Bearings, Mopar Performance Adjustable Pinion Snubber, Hi-Jackers Air Shocks
OE Rear Sway Bar Powder coated
Mopar Performance Super Stock Springs
Dons Speed Shop DriveShaft
727-A Transmisson with Shift kit Mopar Performance Deep Pan, Mopar Performance High Stall Converter, B&M Flexplate
14 x 6 in Rally Wheels 2 4 x 5 and 2 4.5 x 5 BF Goodrich Tires
Moog and TRW front suspension Components
1970 Kelsey Hayes 4 Piston Calipers
Firm Feel Industries Front Sway Bar
Fuel Tank and Fuel Sending unit replaced
Fuel lines, Brake Lines, Brake Hoses Replaced
New Wheel Cylinders
Legendary Auto Interiors (Headliner,Vinyl Top, Seat Upholstery)
Has Original AM/FM Thumbwheel radio (Works) and Original Speaker in Back.
Original Antenna and Wipers (anco) and Trico Wiper blades
Frankly this had the best of the best put in when I built it. The 360 motor I had in it
Was replaced with a Running 318 from a 68 Coronet. Heads were freshened up but the
Will need to have a hone and re-ring soon. I’m asking $15,000 Firm and with it for THAT price
Will be a new Snap-on 2 piece toolbox worth $1845 and any parts I have for the car. It all goes as a package. Any modification to the price the toolbox does not go with the car.
http://s128.photobucket.com/user/mpalos1/library/1969%20Dart%20w%2070%20Front%20end
Some of the earlier pictures here at this link:
http://s128.photobucket.com/user/mpalos1/library/Dart
Also the BAD. The right Qtr starting to bubble, trunk has no holes i'll get pictures soon of it. I'll clean it out. Also Last year a metal bar was flying through the air on Hwy and skimmed off my hood. put 2 small dents in it. See picture. Passenger seat bottom stiching let go about 1/2 inch. Never kneel on your seats. Cand be fixed still solid. Thats it for Damage report.
Mopar mini-starter
New Wheel Cylinders
