1969 Exhaust manifolds
1969340dart
Porter Texas
My soninlaw is using the HIPO exhaust manifolds on his 69 Dart 340 Swinger. Not sure if they are the 69 model or what but he is needing to know if there is a place to buy the stock style head pipes or does he have to have them custom made.From looking there is not much room in there for error and it looks like th ebottom of the driver side manifolds bends toward the front of the car which will require a substantial bend in the head pipe.Anyone running stock manifolds on the 69 and can you give us a lead to purchase the headpipes.
Thanks
Bobby
TTI makes pipes that fit the '69 340 exhaust manifolds:
http://www.ttiexhaust.com/
By the way there are casting numbers on the sides of those manifolds. You may need to hit them wire a wire brush to clearly see the numbers. I would not order any pipes until you are sure of the manifold numbers.
