Section 23-67
In adobe pdf, page 1125
I think that's a good idea.Bill if you want come down to happy valley (SE Portland) I'd be happy to help you out. I have switches et.al here. Plus a few you can look at.. I'll send you contact via PM.
Oh my....do I have a lot to learn~Thank you.... I did find the pages, and our page numbers match. I've printed them out and believe I now know the correct part numbers of the pivots and crank.
Looks the same to me Steve,, everything is as it was when I removed it. The grooves in the arms face each other and the tie rod is on the lower pin with the drive rod with the kink in it (toward the wiper pivot) goes on the top pin as installed on the car.Larry it looks like in your pics you have drivers side in the right in your pics?
Also your bracket/link on the left in your pics. I dont have that in mine?
Well well...My RH and LH Pivot's are the correct part numbers. Assuming the drive and connection links are correct, I need to find out why the wipers are not parking. Thanks for the tips guys!Oh my....do I have a lot to learn~Thank you.... I did find the pages, and our page numbers match. I've printed them out and believe I now know the correct part numbers of the pivots and crank.
LH Pivot S/B P/N: 2857935 Mine is 2857935 !
RH Pivot S/B P/N: 2857934 Mine is not known!
Drive Crank S/B P/N: 2822272 Mine is not known
And of course, why my wipers are wiping lots of paint and chrome and such....Well well...My RH and LH Pivot's are the correct part numbers. Assuming the drive and connection links are correct, I need to find out why the wipers are not parking. Thanks for the tips guys!
