69GT
Full set of side marker assemblies from a 69 Dart. Included are all four housings and lenses and the fronts have the rear mounting brackets with the correct mounting nuts. One of the red lenses is cracked but the other three look good. A few of the little plastic push-in clips on the back of the lenses are broken off so the lenses will need to be glued or double sided taped in. The rears have a little of the quarter panel with the screw mounts still attached from when they were cut out. $85 for the set plus postage.
