[SOLD] 1970 340 engine rebuilt ready to go and a 472 Hemi motor
jwhitebird
Active Member
Duluth
Rating - 0%
0   0   0
1970 340 for sale its rebuilt and ready to go, also have a 472 Hemi motor, I'm listing for buddy
70' 340 is $3500
472 Hemi (world Block with aluminum heads) $16,500
Motors located at 55720 zip code
Nice looking engines!!!
You need to pull your phone number from you add, as per the rules here to avoid deletion. Just ask for folks to PM you for the number.
Good Luck with the sales. :thumbrig:
10:1 .030 over. Steel crank std mains. .010 rod bearings. .004 crank end play. ARP rod bolts. Balanced rotating assembly. Rod side clearance .018. Rings .020 2nd ring and .016 top ring. Hardened valve seats. Valve springs good to .520 lift. 1.88 J heads
Jwhitebird,
Would like to make a offer on your 340 please contact me.
Giby
Eden Prairie, MN
