[FOR SALE] 1970-73 Dart/Scamp Rear Unibody Cap
whitepunkonnitro
Murfreesboro Tn
Rating - 98.2%
162   3   0
I've got several of these, all straight and rust free. All are still mounted to cars, so I can cut as far forward as need be to repair crash damage or if you need sections to adapt 67-69 rear quarters to the later cars. $100 each...add $25 each for the bolt on quarter extension caps. PM me if interested. Thanks FABO!
DO NOT currently have any rear valances.
I know this is not for the part you listed but is that green one a 4 door and if so what condition is the vinyl in?
By removing the trim all around it, but is it a 4 door?
You're probably new to this, but...it's absolutely impossible to remove a used vinyl roof from one of these cars. It's glued to the sheetmetal and usually so dry and brittle that it will tear like tissue paper if you do manage to get any of it loose.
