[SOLD] 1970 Dart Duster 4 speed Reverse Lockout Complete Assembly
Cubzy
Canada
Rating - 66.7%
2   1   0
Complete 1 year only 4 Speed Reverse Lockout Assembly includes everything you need to install. All connected together and photographed in the position it was removed to reference for reassembly. Includes both hard to find rods with washer and correct pins. Includes the rotating shaft with frame mount(correct bolt) and 4 speed bellhousing mount(correct bolt). Also includes factory bushings on both ends of the rotating shaft.
$500 plus postage to you. Thank you
