1970 Dart tail stripe location?
FJ5
chickasha, Ok
Does anyone have the measurements for the location of the tail stripe on a 70 dart swinger? My painter is having trouble finding the correct location. Any help would be greatly appreciated. Thanks Jon
put the side stripes on first then that will tell ya where to put the trunk stripe & the side marker lights will help with alignment
Painted on? I did! I laid out my own, it's wider than the original.... I used 1/4 in tape on the edge of the quarter panel to be the starting point of the small outside strip then made the center 7 3/4 wide.... then added the other outside strip... I also ended the strip all the way down to cover the valance from the side... Hope this helps... if you want to go original specs don't do it like me.
i think the side marker lights line it up best. but remember the trunk part of the stripe is NOT just straight across the trunk.
