thought i'd list the new parts that are eather on or come with the dart. black vinyl top,black headliner,black dash cap,steering wheel,all weather stripping,soft brake lines,hard front brake lines,brake pads,calipers,portioning valve,ball joints,tie rods,all front end bushings,disks,wheel bearings&seals,s6 to v8 motor mounts,rebuilt 318 w/ new clevite 77 bearings, total seal moly rings,roller timing chain,MP lifters,earson cam,edelbrock 600 CFM ele chock carb, edelbrock performer intake,hooker headers,MP ignition w/ orange box,summit racing eletric fuel pump,altanator,water pump,steering box,pitman arm,idler arm,eletric fan,turn signal lens,master cylender,MP valve covers,edelbrock air cleaner,tires,rear wheel cylenders,B&M shifter,u joints, and a lot of other odds and ends i'll only think of after i post this!!!! other things that are not new but were replaced, car was converted to front disk brakes, and a large bolt pattern 71/4 rear from a 73 duster was installed,also another new part installed is both front floors were replaced with patch pannals from the paddock.there is 3 gal of dark blue matalic paint too. the engine compartment and door jambs are allready cut in.
