[SOLD] 1970 Duster - 408 - 20K Final Reduced Price!
Ricks70Duster340
Child of the King
Sisterdale, TX
Very nice, solid car with all the typical challenge areas taken care of so you can have fun. I've owned it since 11/2020. BluePrint Engines 408 stroker (dyno sheet showed 465HP) with about 4K miles on it, Edelbrock HP mech fuel pump, MSD distributor, Airgap intake, Dougs headers, ME Wagner PCV, fresh 727 w/3000 9.5 PTC converter, H7B trans cooler, B&M Quicksilver floor shifter. Strange 60 3.55 rear, Strange 1350 driveshaft. New leaf springs. Front 215/60/15, rear 275/60/15. Bilstein shocks. Manual steering/brakes. New front end with QA1 K-member, UCA/LCA's, PST strut rods, 1.03 torsion bars. Flaming River tilt steering column. Corbeau seats. New under dash wiring harness. New aftermarket dash bezel. New door panels & carpet. New engine wiring harness. Quickfuel 750 VS carb with OE style 340 air cleaner, Lokar throttle/kickdown. Champion radiator, OE style shroud, mech fan with short clutch, flowkooler water pump, 180 hiflow thermostat. Over 50K invested in upgrades, priced to move for $20K. Need to move this guy ASAP! Located in Boerne, Texas (just north of San Antonio).
Any chance to get a better pic of the fender tag?
Do you have the original seat mounting brackets to go with the front seat? Do you have the original radiator and shroud? Do the original 14" rallye road wheels come with the car? Is the car still original small bolt pattern with the 4 piston Kelsey Hayes calipers?
Is the thumb wheel radio installed and still works? Factory front sway bar still installed and if not do you have that? Is the rear exhaust pipes style with turn downs still in place ? Do the factory rallye gauges work?
Do you have the automatic column shift setup ? Do you have all of the factory throttle kickdown linkage?
Has the rear end been rebuilt ? Still SBP?
How is the chrome for both bumpers? Do you have the factory 340 cast iron exhaust manifolds? Do you have the original 340?
Possible to post a HD video walk around ? and a driving video ? Video of the underside front to rear on a lift?
Any issues currently with the car - i.e. leaks, run hot, pinging, hot or cold start issues, trans. shifting issues, suspension/brakes ok?
Thanks for any info.
Sounds like you want to restore it to original condition. No, don't have (sold most of the) original parts you're asking about. No issues with leaks, pinging, etc. Rear end is the Strange 60 (dana style) with BBP wheels.
3.54:1 rear gear?
Whats with the A/C, also do you any pics of the inside of the trunk ?
