1970 Duster
I have never done that before! are there any instruction out there on how to do it that way? I will check out youtube!
You basically remove your torsion bars, unbolt the front suspension (shocks and UCA's), remove the 4 k-member bolts and lift the body up.
if you do want to go from the top , take the hood of, the radiator out, and if possible, the upper radiator support
then it will be a piece of cake
