dd70340
All the gauges in 70 Dart 340 were working properly last year. The car sat for several months and now only the temperature gauge doesn't work. I grounded the sending unit plug using a test light and it flashed dimly about once every second. When I directly grounded the plug the temperature gauge needle moved less than a 1/16 of an inch. I tried this several times but the needle moved about the same distance each time. Is there anything I can try to get the gauge working short of taking the dash apart?
