[SOLD] 1970 Roadrunner 383 4 Speed in NJ
68gtxman
I used to reMember
Eastampton, NJ
$15K takes it all. New quarters (uninstalled), trunk floor and extensions (uninstalled), plus grill, taillights and bench seat, pistol grip shifter too.
More information needed, does it move under its own power ? Any brakes, have you tested the transmission?
@frodo84
It has a clean/clear title in my name. I traded for it about 15 years ago. I started it up with a hot wire back then because turning the key didn’t do anything. I drove it onto the trailer to bring it home and I rolled it into my concrete floored barn, where it sat ever since. I never checked the engine (which did run back then) or tried to figure if the starter solenoid was the issue with the key. I would plan on taking the whole thing apart and rebuild it from the ground up. Brakes worked back then too, but never used since then. This is not a turnkey, drive it home car. It is also a manual steering, manual brake car.
