Catman69
Active Member
1970 Standard bore 383 block..Uncut forged crank..1967 Hp 915 Heads..
8 brand new Speed-Pro 2315-30 forged pistons on reconditioned rods with ARP bolts..Pistons and Rods have been weight matched..Clevite Rod and Main bearings..Durabond Cam bearings..Speed-Pro R9590 Plasma Moly ring set..Block hardware kit and distributor bushing..Will also include virtually new XE274H Comp Cams camshaft....Rocker arms and shafts..Push rods..Roller timing chain and gear set..Timing cover and chrome valve covers..$900 OBO for everything...Will separate...Located in CT..
