Right on Joe! I am a purest at heart but the LS/4L combo's do have a lot going for them.
if the assholes at chrysler weren't so anti enthusiast for so long you might see less of this type of swaps. but fact of the matter is that there is far more aftermarket support for a LS then a modern hemi.. just the way it is, can't argue the fact ... looks to me like a smart swap.. i believe the LS is a little more narrow then the hemi and fits an a-body well..
If I were to personally take the plunge into something like this I would really go against the grain and use a Drivetrain out of a 86/87 Turbo Regal. I know how to make them run and get thrown out of a track for lack of safety equipment. 25mpg, extremely driver friendly with a nice overdrive, and easy to maintain once you do the simple things necessary to make it live for 11:40's in a 3300lb street car...
A great classic 1986 REGAL LIMITED with 90,126 miles all original Paint very Solid car.
Too many new Parts to list, ready to go anywhere turn Key and go enjoy your new Ride.
Asking $4,500 If you looking at ad YES CAR IS STILL AVAILABLE.
i hear the guys buying alter-k's with the ls mounts drop them in, get a set of 300 dollar headers and go..
theres one that has been for sale locally on craigslist that i have had my eye on.. i don't know what to even look for though and if its a decent price.. love the car though...
HemiDenny, I really appreciate your response. My plan was to build a custom K member, that way I have a solid place to mount the Mustang II steering rack without having to mangle some mounts onto the factory K member.I see a lot of good hot hottin' going on here. Probably going to take some custom upper and lower control arms if you are going to use a factory K w / factory geometry.
I already built a K with a C6 front end mated to it, It's called the XV VTR suspension...HemiDenny, I really appreciate your response. My plan was to build a custom K member, that way I have a solid place to mount the Mustang II steering rack without having to mangle some mounts onto the factory K member.
you're gonna let her drive your car!??!?!Thank you for the pics. That will be very helpful when it comes time to fabricate mine.
This project was pushed aside all summer. Finally got concrete poured in the garage and while everything was emptied out, the car sat outside all summer while I was busy boating and motocross racing. Now I've actually got 2 Suzuki RM 250 2 strokes for sale if anyone is interested!
I just got back to working in this a couple days ago. I've dusted off the Vette suspension and re-inventoried all my parts. I also had a real heart to heart with myself and realized that the car will never recirrethr appreciation it deserves unless it had a Gen 3 Hemi. I started another thread in the New Hemi Swap section about choosing the correct engine to use, and I am heading to the pick n pull on Saturday to get a truck 5.7 and 545RFE transmission. My girlfriend can't drive a manual and I know she would have fun with the car as well, plus I don't really like the manual options for a Gen 3 Hemi. It's rather $3,000 on a Viper T56, or a non overdrive 833 and I want overdrive.
Last week at the same pick n pull, I had to help my brother get a transmission and K frame for his Honda Accord and while we were there, I snagged the rear differential from a 2006 Ford Explorer. The axle code is 46, so it's an open carrier with 3.73 gears. I will eventually have to swap out the carrier for a limited slip, but I found the 2006+ diff that I wanted with the much beefier mounts.
Pictures won't help, there's about $500,000 worth of design and R&D sitting there, the geometry and shocks are the key.
Best of luck...
CR
I take it you are aware of the compression ratio being increased above 11.5:1 with the Eagle heads on the 04 block right?So yesterday I went and got the Hemi. I found a 2004 Ram 1500 2wd at a local pick n pull with the 5.7. I got the engine, transmission, and harness from the Ram, then, in the same row was a 2009 Chrysler Aspen with the Eagle 5.7. We snagged the heads, valve covers and coil packs from it. When I pulled the heads, I found that the #2 cylinder intake valve suffered from the typical valve seat failure of the early 03-08 Hemi's so it looks like it will take a trip to the machine shop and a new set of pistons. Not really sure yet which way to go with what pistons to put in it.
As far as the transmission goes, I plan on using the 545RFE but may end up with a Transgo shift kit but I also need to find a 2007-2008 Ram PCM so I can access the transmission tune with HP Tuners. I also grabbed the rear driveshaft for the truck so I can use the truck slip yoke.
Enjoy the pics! So far this is just some of the damage and the engine cleaned up with some Gunk Engine Degreaser and my pressure washer. I plan on tearing it down later in the week.
from what I researched on the LX swap forum, 10.5:1. Ethanol is also an option it appears. The head gaskets appear to be the simplest solution. One thing too, it appears that longer push rods will be needed if one does the Head gasket fix.Yes I am. And I've read where the remedy is typically thicker head gaskets. But it looks like since I'm going to have to buy new pistons anyways, maybe I have some options for compression ratio. Does anyone know the max static compression ratio for a 5.7 Hemi on 91 octane fuel? Obviously camshaft selection and timing have a huge affect on octane tolerance but I'm sure someone has a generally safe number they stick by
Are you guys back in business? I really like the Hemi intake that you guys used to produce but they seem to be impossible to find anymore, even on the used market. Just wondering if something like that could be expected to return.
