Speedotann
I have a 1971 400 Bare Block For Sale! Hard to Find Casting is 3614230 and YES, it is the block with the HUGE webbing/saddlles! Stock Bore
Let me tell you about how I got this block. I first picked up a 73 400 block. It was sonic checked and had horrible core shift. It was scrapped. I then found another 73 400 block which had the same fate due to core shift. I Then found this Block I have for sale.
It has been through a hot tank (still needs shot blasting), It was magnafluxed (passed), and best of all, it has been sonic tested. The guy (same guy who tested and failed the other two blocks was doubtful this one would pass) said it was the thickest Big Block Mopar he has ever tested. As you can see in the picture of the test sheet, all of the thrust walls are super thick. It Does come with the Stock Main Caps and Bolts just not pictured.
If you don't know about these blocks... Read this on 440-source
http://www.440source.com/blockinfo.htm
This Block would be a Great one for a Higher HP build.
This is the closest thing (In Strength) to an after market block for BB Mopars (without spending 4k it). Don't waste tons of money gambling on unchecked blocks Plus Sonic Test Fees (trust me)!
$1,500
Pick Up Only From Bakersfield, CA 93313.
PM Me If Interested
$1,500
PM Me If Interested
