340sixpack
1971 Dart Swinger
440 engine,55 over 451 compression 12.8-1 machine work by Gary Ostrich.
Steel Mopar crank,JE pistons,Eagle H beam rods,main caps milled with billet supports,studded.
B1 BS heads ported by Koffels,flow 355 @ 700,Koffels rockers 1.6 ratio.
Reed cam lift in/ex .681,duration in/ex.322 @ .050= 285
Crower roller lifters,Smith Bros.push rods
Indy intake
Demon 1090 gas
Body
Back half car,stock floor pan,all glass and regulators,car all steel other then front bumper and hood.Painted 2 yrs ago.Had Minor lower rear quarter rust,rest of car rust free.
Chassis
stock front suspension/torsion bar,steering.
Front brakes Aerospace.
Dana 60 rear,Mark Williams axles,4:88 gear
FastShaft chrome Moly driveshaft
Rear brakes Strange Eng.
32x14 rear slick
Transmission
727, case prepped for transbrake,not currently installed,will go with car.Vent moved to rear.
Coan converter transbrake compatible
CSR carbon trans shield
Shiftnoid electric shifter
XP 16 volt battery,with charger.
Engine and trans have a weekend of racing,12 passes.
Best time 10.33 @ 131 mph,foot braking,did not have much time for tuning before eliminations.
Chassis was certified to 8.50,expired.
Belts and net expired in spring.
Car is well built,drives great.Have title.
$26000
Located in Perry,IA 50220
Indy intake
Demon 1090 gas
Body
Chassis
32x14 rear slick
Transmission
$26000
