Most turbo's when balanced have the ends of the impeller shafts shaved for balance. That star lookin part on the end on the turbine side, and the nut on the compressor side. If there not balanced, soon as you build boost the turbo will go boom!
AnotherA,
Did you have presence on www.theturboforums.com?
Is that the VS racing that you bought through?
The master power series is very strong on the turbo forums. They have had good response, solid performance histories, and those guys really challenge a non performing product.
There are also a ton of guys over there that are running a blow through carb setup. There are some things that need to be done to the carbs, but they have a DYI section, or there are several vendors that will make the modifications, or sell you a complete carb, ready for blow thru.
I am looking to GN turbo my /6 Dart. GO FOR IT!
Love that pump! I was gonna use it on my TurboScamp build, but I want it in the tank. As you now know, that pump is WAY too big to fit through the stock tank opening. I'm looking for an alternative...
I'm going to mount it on the passenger side frame rail just in front of the tank.
Going to drop the tank clean it out and then tap a return and put in a larger pick up.
Anyone know what the Ohm range is for the sending unit? Is it 0 empty/73 full?
