Thats correct as outlined belowpretty sure he recommends the 71 up B body shifter for A bodys....
It follows the beveled edgeLooks good, but I think I would have the stripe a little wider behind the door, closer to the beltline near the quarter window.
really looks nice! I always struggle with graphics.It follows the beveled edge
It definitely take meticulous patiencereally looks nice! I always struggle with graphics.
TA race cars pretty much all used 15" Minilite mags.They are legend wheels torq thrust 2 style not ford, they look awesome compared to the tin can boomer Chrysler wheels
They sure did but im dong mine as a resto mod cause it looks good sitting on 18’sTA race cars pretty much all used 15" Minilite mags.
Yup its on my list to doJust a suggestion..
Ever think about a flip-top gas cap like the 69 Cuda?
there's 18" minilites available...They sure did but im dong mine as a resto mod cause it looks good sitting on 18’s
What do you screw i to the rubber?#damraider sells the adapter on FABO - here is the one on my 70 Dart GT
I like the "Super Stock " springs. Helps to keep the car flat in curves. Remember the TA and AAR's were road cars not drag cars. I agree with an upgrade in shocks, being you are deviating from a stock format. When you present the finish car, the first place a Mopar person will check out is the TA marking on the block. Sounds like you are building an awesome ride. You going to exhaust out the rear or in front of the rear tires?i agree on some modern shocks.
as said, you've already deviated from a true replication with some modernized components so i'd stay the course with that.
you may not need a rear swaybar depending on your set up.
see if you can figure out what your rear spring rate is (HD tells us nothing) and then select t-bars that will compliment that.
Correct me if I'm wrong here but doesn't the super stock spring package also include an extra spring on passenger side to help offset chassis twist under hard acceleration? Good for straight line, not so much for handling.Super stock springs are for drag racing. They raise thr back of the car too much for good handling, and they’re actually too stiff for good handling as well.
As for checking for the T/A casting, seems silly because any Mopar purist would know that they never made a T/A A-body. So it wouldn’t be correct even if it had one.
Going to be running the exact T/A exhaust system i was told should be direct 340 bolt in except the side muffler hangersI like the "Super Stock " springs. Helps to keep the car flat in curves. Remember the TA and AAR's were road cars not drag cars. I agree with an upgrade in shocks, being you are deviating from a stock format. When you present the finish car, the first place a Mopar person will check out is the TA marking on the block. Sounds like you are building an awesome ride. You going to exhaust out the rear or in front of the rear tires?
