72demon
fresh built 01/20/1971 340 serial number 2b103998 as near as I can tell numbers were not stamped very well 40 over 10-5 comp sealed power pistons 10/10 crank semi balanced
X heads (big valves) this one is not cheap 6000 k with core must be a 340 7000 with out core
can be installed if you want to provide transportation or I will come and get for a fee depending on distance 1000
