1971 Dodge Dart PARTS AND ADVICE NEEDED
California
So im currently restoring a 1971 Dodge Dart with my Dad and we are gonna be swapping out the motor from a slant six to a 318. We have the exhaust manifolds but I need the exhaust, does any one happen to have good exhausts for sale? I'm also looking to change to electric ignition instead of points. Does anyone have Electronic ignition distributor and wires?
So I'm working on a 1971 Dodge Dart she is fully running and functional but i am swapping out the motor to a 318. I have the exhaust manifold but need the exhaust. Does anyone by any chance have exhaust's that will fit a 318 exhaust manifold? I'm also looking to change to electronic ignition instead of points. Does anyone have a Electronic ignition distributor and wires?. Any advice would be appreciated. Thank you
Ask member Whitepunknitro...... I buy a lot of '71 parts from him.
Welcome to the madness!
too bad you're not in Phoenix. I have a complete dual exhaust for a 71 and a 318 sitting here. Pulled it off of mine when I upgraded everything, including the motor.
Welcome to FABO, are you looking to buy new parts or used?
You do realize that the transmission and k-member do not bolt up from a slant 6 to a V8 right?
What are your plans for the car performance wise?
If you do a lot of reading in here, there is a lot of good info on this swap.
Try using the ''search'' function and you will get hours of reading on this topic right there.......
