Ironracer
Gearhead
I had one that said "Chrysler Firepower" on the Valve Covers.... 12.5 :1 and .060 over!Firedome hemi and a 5 speed please.
Awesome project
Awesome project
Lay em in the Sun. And Tight is Right Brother!Seat looks good, I hated doing mine years ago, the covers were real tight.
Black, butt burners. I did mine in white.
Sick!I had one that said "Chrysler Firepower" on the Valve Covers.... 12.5 :1 and .060 over!
Yessir, someone liked it more than i did. Cause they took it out of the garage when I wasn't homeSick!
Holy F that sucks. I hope they rolled it onto their footYessir, someone liked it more than i did. Cause they took it out of the garage when I wasn't home
Thanks Brother, 392 Hemis and Heads Don't grow on trees. It was back in the 90s but every now and then I still get pissed off about it...Holy F that sucks. I hope they rolled it onto their foot
What would you like to know about it? It is/was a stock 8.25 out of a 74 Duster, had a doctor diff suregrip unit and 3.73 gears put in, all of the brake stuff is 2005 Jeep Liberty. I put 275 60 15 wheels/tires on it but i am going to have to run a 1/4" wheel spacer for leaf spring clearance. Anything else you need to know hit me up and ill see what i can docan you give more details on that rear end and measurements please!
Zanesville? Ohio?Got some more work done today, rear brakes are fully in minus the lines,
rearend cover gasket out for delivery so that can go back on, and installed the 275 60 15 wheels/tires.
I'm going to have to run a 1/4" wheel spacer for leaf spring clearance but should be good to go.
Also finished tearing the motor down to block/heads. COuldnt find the bolts i need to get it on the engine stand yet so
Heads will have to wait until tomorrow.
Also have one stuck exhaust manifold stud and one broke off intake bolt thats gonna have to be attended to.
Currently enough sticking out of both to weld a nut on and try to remove that way. Hoping to avoid machineshop fees,
especially since nobody in Zanesville wants to work anymore.
Good attitude to have.Thanks Brother, 392 Hemis and Heads Don't grow on trees. It was back in the 90s but every now and then I still get pissed off about it...
Just found out a Friend's Dad/ Customer/ Work Reference and Referral Man Passed. Solid Man. Good Christian Dude. So in the grand scheme of things, it was just a few chunks of metal I guess
YupZanesville? Ohio?
Those are the same floor pans I have for my 71. Did you stitch weld or just plug weld them in?Now that the car was back on all 4 wheels/tires again, i Started attacking the interior again.
Floor pans are all cut and in, driver side is fully welded in, passenger side still needs some dickering to be done-done.
Started disassembling and dewiring the steering column and dash, and prepping everything for paint/primer.
Once the floors are fully welded in on passenger side, and dash/column are painted the long laborious task of installing the Painless Performance wiring harness can Begin!
to be honest... i am not thrilled with the floors.Those are the same floor pans I have for my 71. Did you stitch weld or just plug weld them in?
I would not sweat it, if it is structurally sound, concentrate on get it moving under its own power.to be honest... i am not thrilled with the floors.
The car really needed and deserves the FULL DROP from AMD that is out of stock/backorder with no return date from literally everywhere.
Some of it is plug welded, some of it is pop riveted, some of it is full seam welded and stitched in with random steel plates. Its solid, but its not Right.
In the future (probably NEXT winter) if the AMD full drop ever comes back in stock I'll pull the interior out and redo it the Correct way.
