Tayseer alhamad
Kuwait Mopar man
What does this connect to ? Maybe for headlamp delay bazar?
Those are the wires mattax if you can direct me pleaseI'm not that familiar with all of these options. Someone else here may be. Also the diagram you show is a little different than the one in the service manual.
Let me see what your car came with and see if I can make heads or tails of this.
edit: looking at your information sheet I only see the A01 package listing the time delay ignition switch light.
Headlight on reminder is possible.
That is different than headlight delay (leaves the headlights on for a few minutes), an option that seems to be very very rare. (see here)
Do you have an ohm meter or continuity tester?
If so, look and test to determine if one of the black wires connects to a matching wire on the headlight switch connector.
The black double and the brown are connected inside the switch.Black wire single goes to steering column second pin black
Yellow tracer and black goes to switch light 2 pins black double and brown
That what I was thinking and thanks for you input MattaxThe black double and the brown are connected inside the switch.
The black double is power to the tail and parking lights.
So yes the gray T shaped connector is for the headlights on warning buzzer.
I think this is extra cable for future connections it is in same circuit with steering lightThat what I was thinking and thanks for you input Mattax
Excellent job this is what I was afterThat I don't know. The M2 circuit yellow wires are from the dome light and are hot.
Here's corrected factory diagram for the accessory light package.
Really what you want for assembly is the cable and cable routing diagrams. Some are in the shop manuals. '71 has more than most years.
All cables are on the assembly drawings. I'm not sure if Faxon has published any assembly drawings for 1971 A-bodies. They have exclusive right to publish those.
Not sure what that is! Not a headlamp on warning buzzer though for sure!Very good information, what this relay for
NOS MOPAR HEADLAMP ON BUZZER 1971-3 A BODY & CHRYSLER MODELS | eBay
Post in thread '1971 duster'I have not done Any color drawings for 71 yet. I can or maybe able to download an original 71 Shop manual and assist if still needed.
Lots of DR. appointments the rest of the week but willing to find some time between them. One thing for sure is a need to understand all the options on ones "Your" vehicle if available to locate the exact diagrams in play.
They "Chrysler/Plymouth" original diagrams are usually all there though, and reading between the lines is required! JMO!
