ok so should i do front and rear sway bar or one or the other? i have heard mixed things on doing both so whats your opinion on it?
Do both at the same time from the same manufacturer. There matches and work together.
and for the rear i was looking at super stock springs and shocks the kit below, more or less but not until i do more research on it
Mopar Performance P4120863K1: Super Stock Suspension Kit 1964-76 A-body | JEGS
so if you look at those and compare them to what you have what the difference? pros and cons not including price because i dont really care about the price
S/S springs are racing spring many use in the street with some complaints about being to stiff, off set ride heights, sitting higher on one side. This has been the way it has been since the dawn of time and how people complain about a bird flapping its wings to fly is beyond me but they do.
But this is why I went with the espo springs. There not as stiff as the S/S springs but did so very quite well handle the power I had at hand in my 318.
In my drag Duster, I have S/S springs and that animal is different and not daily driven as my other Duster is. (Or was...)
and final question for this comment whats your opinions on if any on edelbrocks top end packages?
They are very good but not without its caveats.
I would have the cylinder heads checked out before installation and possibly ported depending on application. (HP needs and desires)
Intake, Double check fit (again) and port if need be.
Carb, There very good. Jet it, set it, basically forget about it. Clean the air bleeds with carb cleaner once a year and your good to go.
While you leave power on the table (only a little bit) next to a Holley, being they are super tuneable, they (Carter/Edelbrock) are a very dependable carb.
