[SOLD] 1972 340 4 speed Duster parts
I will sell the 72 340 engine for $ 1500.00
The complete 4 speed trans with shifter , bell housing with fork, Clutch and PP, fly wheel for $ 1200.00
The pedals and all the linkage, Z bar, frame plate. For $350.00
The 72 floor P/S column for $250.00
4 Speed drive shaft for $175.00
Original A body 8 3/4 with a open differential which I believe is a 3.23 for $1200.00
Bucket seats which are shown in the picture. Not sure if they are A or E body Hi-backs for $250.00
Plus anything else off the car, just ask
pm sent on 4 spd parts
Is the motor original to th he car? If not can you post the VIN on bottom side of block above the oil pan?
No it is not the original , but it is a 72 340. I won't be home for a few days. Contact me like Tuesday and I have it written down.
Well I sold the pedals with all the associated linkage, 4 speed shifter and the 4speed floor hump. So the parting out has started. Let me know what you need.
Up Dated List
I will sell the 72 340 engine for------------------------------ $1500.00
Still have the 833 4speed trans, bellhousing, flywheel and clutch and pressure plate---------------$800.00
The pedals and all the linkage, Z bar, frame plate. For $350.00 (SOLD)
The 72 floor P/S column for-------------------------- $250.00
4 Speed drive shaft for------------------------------- $175.00
Original A body 8 3/4 with a open differential which I believe is a 3.23 for------------------------------ $1200.00
Bucket seats which are shown in the picture. Not sure if they are A or E body Hi-backs for------------- $250.00
Picture of the booster, I removed it. Comes with the inner fender brace and the brace running down to the bottom of the firewall.
Just pulled the engine out today. Cast date 1-15-71 Crank will except the manual trans input shaft. Had a 4 speed behind it. As you see it in the pictures $1500.00. Less if you want to buy it less some of the parts. IE: pulley's, Holley 800 DP, Engine motor mount brackets.
1972 340 Duster K-member ( with the welded on washer) sway bar and mounts, Lower control arms with sway bay tabs, 340 torsion bars, Power Steering box and all the steering pieces. Tie rod ends center link, Strut rods,idler arm and Pitman arm. $600.00
Howdy! Did the trans, bellhousing, flywheel, clutch, pp sell yet? Does it come with shifter?
How about the steering column? Does it have key with?
What would you sell those items, as a packaged price for?
I'd come and pick them up, if great price!
PM sent
How much for the firewall / tunnel section?
Need about about 12" around the tunnel including the harness /firewall opening area
I'm going to be gone from home for a while. If you are in no hurry I'll get with you and see exactly what your looking for.
Roy how much for the LCA'S? How much for Brake Booster?
