torquehouse
'72 340 LA engine, block casting # 2780930-340-1, casting date is 1-15-71. Numbers stamped on pad in front of block below head are MH 340 R 38858011. VIN pad is difficult to read but "2B" is clearly visible. Running 340 engine with fresh (never run) 587 heads installed. Engine has not been run since fresh heads were installed. Standard bore block. Complete long block engine. No knocks, no noises, no smoke. No accessories. $800.00 or trade for Mopar parts/E-body parts. Looking for B/RB engine 915, 516 or 906 heads and LA engine 894 or 915 "X", "O", "U" and "J" heads, Performer/RPM/Air Gap intakes, '67-'70 440 long blocks. Call with what you have. (202) 292-9254 or (301) 455-8499 anytime 24/7. Located 5 miles east of Washington DC. Zip is 20743.
