1972 383 Gold Duster build
A-buddy-72
Active Member
wauconda
IMG_4401_Original.jpegHi, I want to be documenting the build of my 72 Plymouth Duster. I got it a couple years ago from a YouTuber who builds chargers here are some pictures the way I got it
The car has sat 23+ years NA abandoned impound lot
I had pressure washed the car at least 10 times and red dirt still came out of it
Looks like minimum rust, just bent in weird spots.
If you need parts ...grills ,bumpers,fenders,doors, interior pieces, Etc give me a call I have many
Started doing rust and bodywork had lots of help from Marks Cars and Wauconda especially Dan and John.
There are some damage on the frame rail in the rear that couldn’t be banged out so we cut it out and re-straightened it and welded it back in
The car had to be put on a frame machine to pull the back quarter panels back out from the damage that had occurred, also it was the time to straighten out the pinch welds that were smashed up from for a forklift picking up the car moving it around we ended up replacing the tail, light panel and the trunk pan. After doing a little work to them realize it was not worth it if the parts were available.
This door was kicked out from the inside cracked up the frame. I’ve never seen a door this messed up, but Don the body man fixed it up.
So we ended up replacing the tail, light panel, trunk pan, extensions, and other little reinforcements in the rear. It just made it a cleaner job obviously more work though.
So I had to end up painting the car it was my first complete paint job decided on Panther pink
