Dustert73
Stripping bolts since ‘10
Hi fabo! I’ve got numerous parts off the 1972 340 I purchased late last year.
First is the intake, carter thermoquad carburetor, and their related parts. Casting number for the intake is 3671918 with a date of 2-7-73, and the carburetors casting number is 6319s with a date of 08 1 3. Much like the engine both of these appear to be very complete and original. Carb throttle blades and choke blades are free. Mixture screws are stuck. Comes with linkage, fuel line, and everything you see screwed or bolted on the intake. Not interested in parting them out at this time. 400$ shipped in the lower 48.
Next is the exhaust manifolds. Casting number 3418623 date 6-7-72 (A/B/E) and 3418621 date 3-9-72 (B/E). Both appear to not be cracked. Heat riser plate is missing. 100$ shipped in the lower 48
Then we have the valve covers. I believe these are the correct 72-73 340 units. Please double check me. 70 shipped in the lower 48.
Saginaw power steering pump and brackets. 60$ shipped in the lower 48
Flexplate and hardware. 40$ shipped in the lower 48.
Thanks for looking and if you have any questions please ask!
