72DartSwingerV8
1972 Dodge Dart Swinger 2 Door Hardtop. Engine was originally a 318 V8 which has been rebuilt with .030 pistons, larger intake valves, milled heads, edelbrock performer intake, holley spreadbore 650 carb, 340 spec camshaft with Hooker headers, 2.5" exhaust into Dynomax mufflers, and electronic ignition. The original 7.25" rear end was removed and replaced with a 8.25" Sure Grip 3.55 with all new parts. 904 Transmission has been rebuilt with a shift kit. Leaf Springs are new with 1" lift in the back with all new shocks, ball joints, tie rod ends, pitman and idler arm. Brand new tires on the original Mopar Rallye Wheels with the correct 1972 Center caps. Interior is original and in spectacular condition, trunk was lined with new carpet. Has Sunpro tachometer, vacuum gauge, and oil pressure gauge. Car runs and drives great. I have the original build sheet, clean title, original license plates (pictured), receipts to everything done on the car, and up to date registration. Paint is Hemi Orange with the correct bumble bee stripe on the back. Less than 500 miles on the engine rebuild and restoration. This car looks amazing, drives amazing and turns heads wherever you go. Asking price is $11,500. If interested please PM.
