1972 Duster Build with my Daughter
Jim Kueneman
Sonoita, Az
It has begun! For those that watched my Coronet restoration over on the B Body Forum (1968 Coronet 500 Project) a few years ago I am about to embark on a Duster build with/for my youngest daughter! She will be delivered tomorrow! History and what we are doing with her will be coming. The Coronet took 1 year exactly and with help we are hoping this is a 10 month build to the first drive!
We are also getting a '74 Dart to pull all the parts off to put in this roller
Here is what she is wanting to build at first
But decided to go with the factory colors with the Twister graphics.
Edit:
May as well put the bottom line up front. This is what she ended up with....
Is this the daughter we saw with sandpaper in her hand?
LOL... when u said your youngest daughter, and she'll be delivered tomorrow, i thought for a minute you bought the duster before she was born
:rofl:
:rofl:
Yea I noticed that it was not completely clear when I reread it earlier
First afternoon with the Duster. Pulled about 40 lbs of Cholla Cactus and packrat droppings and gutted the interior, if not for a piece of cardboard in the spare wheel well that started some rust it would be perfect. It does need a left inner fender since someone started to hack out big block header holes :(
I let my daughter run the impact to remove the seats and disassemble. She has not given up yet :)
This is what she was from the factory:
VL29:
Plymouth Valiant,Duster Low 2 Door Sports Hardtop
C2B: 225 110HP(net) 1-1BBL 6 CYL
1972 Dodge Main, Hamtramck, MI, USA
107818: Sequence number
E24: 225 cid 1 barrel 6 Cylinder 145hp
D34: Light Duty Automatic Transmission
NB1: Powder Blue Exterior Color
D2B5: Trim - Luxury, Vinyl Bench Seat, Blue
GB5: Bright Blue Poly Int. Door Frames
730: Build Date: July 30
192377: Order number
HB1: Powder Blue Top Color
U: USA Specifications
B51: Power Brakes
G33: LH Remote Racing Mirror
H51: Air Conditioning with Heater
L31: Hood/Fender Mounted Turn Signals
R11: Radio Solid State AM (2 Watts)
V5X: Body Side Stripes, Black
EN2: End of Sales Codes
My big question....will the Pep Boys air cleaner make an appearance on this build? LMAO!!!
Looks like a nice car to build.
Digging around the rear quarters finding out how much hidden rust there is. Was there a shift if metal gauge between 1968 to 1972? It sure seems like the Duster sheet metal is not quite as heavy as the Coronet....
