mopars4life
72 duster unfinished race car project. Can't be put on the road again (dash swapped with another 72 duster). Has a one piece front end that's never had paint on it and is a good replica down to the part numbers on the side markers. All frame rails good and floors are 85% good. Wheel wells were extended. Trunk floor has rust. Was a stick car and still has the pedals, hump and bracket on the frame rail. Has a 73 440 and 727 sitting in the engine bay and it appears a 340 k frame on it. Drum brakes and was a power steering car. No title! Doors are decent and drivers door and dash came from the same car I will be removing the vin plate before sale. The motor was greased before it sat so hopefully a good rebuild-able core. The heads are in the car. Will have a 7.25 rear and roller tires on it. Trunk lid shown will be swapped with another (has rust underneath) prior to sale. Interior is stripped for the most part. Has a good power steering floor shift column and the taillights look good. All glass is good. Quarters aren't bad at all compared with most I've seen. Taillight panel has rust below taillights. If it doesn't sell I will part it out, just seeing if anyone has interest in the whole car to finish it out as a race car first. Asking $1500 and located in northern VA.
