[FOR SALE] 1972 Duster
plymouth67
It be a lot cooler if you did...
illinios
1972 Plymouth Gold Duster
318/ 904 with 8.75 with 3.23 gears
Motor is a reman .040 it has 302 heads with mild port work, Lunati 10200443 cam, Melling HV-72 oil pump, Speedmaster air gap intake, Hooker super comp ceramic coated headers, and Mallory ignition. Engine runs good and sounds awesome. The 904 works flawlessly. It has Dr Diff disc brake set up and axles with green bearings. Power brakes and power steering.
Cars has newer carpet, door panels(front and rear) and seats have been recovered. It has aftermarket gauges and a new OER Tuff Wheel. Interior shows nicely.
The exterior of the car has an older amateur paint job with its share of dings and scratches but, is very solid. There is absolutely no rust showing on the body. The floors are solid. The trunk floor has some pin holes in it.
Car has a new OER Shark tooth grille and rides on a set of 14" rally wheels with new BF Goodrich Radial T/A tires. This is a turn key reliable drive anywhere car. Car goes straight down the road and cruises nicely down the highway. $20,000 obo. May take partial trade for short bed truck.
A buddy of mine is heading that way shortly. We are 3 hours from there. As soon as he gets ahold of owner.
Are you talking about me?? Waiting for a response from the owner. I don't mean to sound like a jerk but these things take time. I wouldn't bother the owner over the holiday and I wasn't going to drive out of state on new years. There are 2 duster's in Illinois and the plan is to check them both out I'm not going to buy the first one I look at that's not good business.
Are you waiting on a response from me? If you are I never received any questions or inquires from you.
