crj1968
Quick run down on the car - Original slant 6 car out of Calif.
Now has spool mount K frame and a nice running 318.
-built 727 full manual reverse VB/ 2500 stall
-8.75 rear 3.23 Sure grip
-Front Disc Brakes
-15 inch wheels in back 14's up front. Big bolt pattern all the way around.
-re-done front buckets
-tuff wheel
-OEM scoop and Shark tooth grille (grill has had crack repair has aftermarket turn lenses)
-Hooker Super Comp headers- new exhaust with X pipe. Car sounds great.
-Body work all done - didn't need much it was solid when I got it (minor scrapes/dings all fixed)
-I had the antenna hole welded up when I had the body work done (FYI)
-good tires, M/T 255/60's in back... new brakes all around, new fuel sending unit.
-MSD 6AL
-manual steering.
not an extremely fast car, but runs very good and is reliable. The guy I bought it from (also FABO memeber) was building it up to put a stroker motor in it, but went a different direction.
Radio is missing
Heater is not hooked up
Rear seat has a tear in the seam
Needs final sand, seal and choose a color.
located in boise ID $11,500
Thanks!
Chris
Video of the car here : [ame="https://www.youtube.com/watch?v=DTfhR1dndw4"]1972 Plymouth Duster Walk around (MOPARS.COM) Long Gone Novel cover car - YouTube[/ame]
-Front Disc Brakes
-tuff wheel
-MSD 6AL
-manual steering.
Radio is missing
Thanks!
Chris
