1972 scamp tire size
moparbuilder
Member
Anderson
I have stock 72 scamp with 15" rally wheels what is biggest tire size I can run without rubbing. Thx.
both front and rear this is new build
You need to measure the backspacing of your wheels or you could have rubbing from lack of clearance, even with a narrow tire. If you have the spacing that I have, you can go with P235 60 R15's & be okay. I have a '71 Scamp running with 15x7 small bolt, rally wheels from Wheel Vintiques.
It's been years since I bought mine so I'd have to check the order in my file, but I believe the backspacing they made for me is 4-1/2" or maybe 4-3/4". The P235 60 R15's are on all four wheels & have never had a clearance issue front or rear when turning, hitting bumps & dips, or having passengers.
