Could someone please post a picture of a "Small balljoint" style control arm with the Upper Bushings removed. I removed the bushings from a set today to replace them with the offset style. Does one side have a longer sleeve on each arm?
The inner sleeve fits on the rear bushing on cars with 10" brakes only.Could someone please post a picture of a "Small balljoint" style control arm with the Upper Bushings removed. I removed the bushings from a set today to replace them with the offset style. Does one side have a longer sleeve on each arm?
Ok.. But its "Not" part of the control arm, correct?The inner sleeve fits on the rear bushing on cars with 10" brakes only.
Thank you AJ. It cought me off gaurd a bit, as I have done a few sets in the past.. These were the originals in the arms from 72. They looked like Hubba-Bubba on the sidewalk. As for the Balljoint... I assume thats for stabiltiy. Ie Caster.My KHers did not have the stabilizer sleeve, on any of the three I have had, from 69 to 70. Nor did I install one. The last set of KHers have been on my car since 1999.
The offset-bushings go into the arm such that after they are in, the Upper BJ is as far rearwards as possible.
Yes there is a collar on both sides. I did not put them back on. I appreciate everyone chiming in on this post.I ran into the same question when I disassembled mine about a month ago and that collar came falling out when I removed the bushing. Here is a pic that shows the collar on the rear arm of passenger side arm - I kept it on the cam bolt so I could remember it. I haven't taken my drivers side off yet so will be interesting to see if it has one also. Somewhere I jotted some info on some research I did on what cars had the collar, If I find it I will chime back. My Cuda is a 318 ac car.
That's not a collar. That is a spacer.
The collars I have seen encircle the bushing preventing I don't know what, bushing walk I suppose.
The spacer is used , also IDK for what. But be advised that sometimes when you assemble these parts on the car and then tighten the cam-bolts
Lol you are a good man.Yeah,now those are the collars!
And what I took to be a spacer is nothing more than a spring washer on which I cannot see the parting line nor the hooks, I get it now.
These were originals.. 43 years in place..I don't recall those being on my GTS when I did the front end, but that was 31 years ago...
I too was like... What the *#@! Is this thing that just fell off. At least we know now. Thanks for helping. This is why this site kicks ***.I messed up on my previous post's pics but below are the ones I intended to post. Actually in the 68 Plymouth Factory Service Manual they call it a "support sleeve" and discuss it only being on police and taxi vehicles in the Belvederes and Satellites. In an old FABO thread concerning these sleeves someone said they were used on older A bodies then discontinued: Help! What is this part?
View attachment 1715045301 After I pressed my bushing out this "sleeve" fell off and I wondered what the heck that was for! You can see it on the left arm - I put it back on the bolts so I remember to reinstall it when I put the new bushings in.
View attachment 1715045302 Close up of the sleeve. I would be curious to what type of engineering analysis went into deciding they needed this sleeve on certain cars!
That is ridiculous!!You sometimes find those "Sleeves" on the rear bushings, on the Slant 6, A body, line of cars.
Why, who knows anymore?
50 years ago, some engineer with Ma Mopar, must have thought it a good idea, for some reason, to justify his salary, with the company, or keep his job.
In all the foregoing years, they didn't do a damm thing anyway.
That's why it's hit or miss finding them on other cars, wether taxis, or high performance police, or B & E body automobiles.
In my rebuilding of UCA's and LCA's and brake parts, i never reinstalled them in my career of working on cars.
I have a box full of them.
You can see i have taken lots of them off.
What is, woodie??That is ridiculous!!
... The fact you kept them all this timeWhat is, woodie??
Not this guy. Always happy, and I try stay dumb.Whew, Ok.
I thought for a minute, that i was going to get into a big internet pissing contest with you, over the reply that i made, about a Mopar engineer.
JV.
