[WANTED] 1973 340 Duster. Fan pulley
Very odd combination. Usually AC cars had PS. Does your AC compressor have 2 grooves?
Yes, seems odd but it’s definitely factory installed ac and manual steering. Two groove pulley on both alternator and compressor as well.
Do you have a water pump pulley? Outside diameter and over all hight?
I was going that route till I realized I have several pulleys and not one corresponds with the parts manual. I’ll get measurements when I get over to the shop on Tuesday.
That parts manual part number feels wrong. If you have one that come on the car, what is that number or configuration?
I’ll check might have one
These found 3 different sizes?
Are you looking a a fan drive pulley (crankshaft pulley) or fan pulley in the 1973 parts book?
From what I can see, the fan pulley you should be looking for is 3418227 for an A-Body. The 3462825 you are looking for is for an E-Body.
I have a single and a double track water pump pulley's
The double is part number 3698805
The single is part number 2953806
