tekslk
I have a stock set of 1973 mopar 360 heads they do not have the 202 valves its thenext size smaller. My questions is what would the cc of these heads be?
hat gets me close enough for now im doing a rebuild and lowering compression trying to get 9-1 or close for pump gas this will get me in the 9 to 9 1/2 range.OEM untouched, most shaft style 360 heads will have chambers in the 68-72cc range. All 360 heads also came only with the 1.88"/1.60" valves, including '72 340's. You will find some '70 & '71 915 heads with 2.02" valves used with those year 340's.
As long as its 62 or better I will be fine thanks for the advice and I know were not 100 percent sure.Probably around 72 but no way to be sure with cc'ing them.
