[FOR SALE] 1973-76 Duster/Dart/Valiant 26" radiator
Moparman1966
Member
Rating - 0%
0   0   0
6" 1973-76 Duster radiator - $225 (Alexandria, VA)
Purchased new from Summit Racing in December 2012. Works fine, with no defects. I switched to an aluminum radiator.
This radiator is fine for stock applications or for engines with minor modifications. Manual transmission. Cost $319 new, selling for much less.
I also have a 26" factory shroud available separately.
Brand:Vista-Pro Ready Rad
Manufacturer's Part Number:433499
Part Type:Radiators
Product Line:Vista-Pro Ready-Rad Radiators
Summit Racing Part Number:pLI-433499
UPC:00040876434998
Radiator Style:Downflow
Row Quantity:2
Radiator Material:Copper/Brass
Radiator Finish:Natural
Transmission Cooler: No
Inlet Location:Upper driver side
Inlet Size:1 1/2 in.
Outlet Location:Lower passenger side
Outlet Size:1 3/4 in.
Core Height (in):18.000 in.
Core Thickness (in):1.250 in.
Core Width (in):26.000 in.
Fan Included:No
Quantity:Sold individually.
Notes:Two sensor fittings with plugs on top tank.
Are you looking for a top-notch stock replacement radiator? These Vista-Pro Ready-Rad OEM Modine-style radiators deliver performance and durability. Vista-Pro Ready-Rad has industry-leading radiator application coverage that is second to none. So, if you need to keep your cool, then you need one of these Modine-style Vista-Pro Ready-Rad radiators.
