unknownsnake
looks good
You planning on cutting down the drivers side of the rear end axle tube or leaving it as is? I am considering the 8.8 for my next Dart project car and plan on cutting it down to match the passenger side plus I don't have quite the room as a Duster or Dart Sport
I ORDERED my Dart Sport in 1976 and still have it...that was 39 years ago. I am the original owner, one of the differences from then to now is the motor. It used to be a /6 but it grew 2 more cylinders. It now is a 360 with 30 over, RPM air gap intake, Eddie carb and a few more mods which give me around 350 HP...just enough power to have fun with.
J.-G.
A 300 plus HP 318 is not an impossible objective, overbore it, 0 deck the block, add a good cam and a 4 barrel with a good intake (like the Edelbrock RPM Air gap) , a dual 2 1/2" exhaust system and you should be in the ball park. You can go fancier by reworking the heads and some more extras but they are not really necessary I think. You don't even have to change the bottom end unless you get into drag racing or have a healthy budget.
Didn't get to work on the car at all since it was my birthday and decided to spend it in the mountains. As tempting as it was to work on the car, the weather wasn't cooperating. Here's some pics from that though:
Balance is the key to keeping stress low...
The car is looking nice!
If your shooting for over 300 hp from a 318, it isn't necessary for an over bore and 0 deck. unless you're replacing pistons already. Mine put down 290 rwhp. Guessing around 340 at the crank. Compression is 8.86 to 1. Small cam too, 210/220 @ .050. Just need some good flowing heads, intake and exhaust.
Gonna shoot for as much power as I can without going too extreme. Don't have a specific number in mind really. Got a set of 302 heads which will get a week's worth of porting and polishing and went with KB167 pistons so I'm not sure I'll even need to zero deck. I did go .030 over since the block was going to the shop regardless. Going with an electric fan, serpentine belt, headers and sticking with the 904 means I should be getting quite a bit at the wheels with this setup.
Got a few of the sound deadening mats down, mainly the roof and rear seat area. Dropped the gas tank and pulled the old exhaust system out in preparation for removing the rear end. It was close to 100 all weekend and I managed to almost knock my car off the jack stands so I decided that was enough fun for one weekend. Pretty limited on what I can do right now until the floor pans get welded in and/or the engine is ready to be assembled.
Only one good pic:
Was able to get it back up on the one stand that sunk into the ground once I wiggled the jack free from under the car.
Got a lot of work done on the car all things considered. Had to drive across the state and back, get my mountain bike ready to ride, rewire my desktop with my new power supply and spend time with my girlfriend and some of her family all in 3 days.
Got the block stripped down so it can be shipped off the to the shop this week, got the rear seats painted finally and finished painting the remaining front end parts I plan on selling. Got started on repainting/undercoating the frontend on Saturday but the rain started at 9am instead of the evening like the forecast stated. Also soaked a few things in some Evaporust and that stuff is pretty magical, highly recommend it.
