69DartGTS
Active Member
Im selling my 1973 Dodge Dart Sport 340. This is a real H code car. The car now sports a mild 360 with a racer brown solid cam, .560/.565 lift .242/.248 duration. X heads 2.02 / 1.60 valves fully ported topped with an Edelbrock Air gap and a FBO prepped mighty demon 650 carb. Ported mechanical fuel pump. The compression is 10 to 1. It also has an 8 quart oil pan with a melling high volume pump. The transmission is a 727 with a JW reverse manual valve body, Ray Bestost clutches and Kaleen steeles, 4 pin planetary and a FTI 10'' Billet converter 3800 stall. The rear end is an 8 3/4 with 3.91 gears, Mark Williams axles. And a MP sure-grip. Caltracs and Rancho shocks and Calvert 90/10 shocks up front. There is about three years on this drive train mainly down the drag strip.
It has 205/75/15s on the front and 325/50/15 MT drag radials on the back. The rear has been mini tubed with the springs moved into the frame rails. Fuel cell and Battery are in the trunk. The car is petty blue and is driver quality paint. It has a white interior with bucket seats black carpet and a nice dash; it has fuel/water/oil gauges mounted on the cowl of the car and a 5 tach on a bracket that mounts in-between the up/low dash. It has a Hurst Quarter Stick shifter and a Hurst ball with a line lock switch. This car runs 8.0 flat in the 1/8 mile and looks like a street car. Jump in and go racing or drive to the drive in. The body is in good shape with no issues.
9500.00:burnout:
9500.00:burnout:
