1973 Plymouth Duster. 340SB bored 30 over. Hughes cam (292/608) comp cam lifters J heads MSD distributor 7AL2 ignition w/2 step box. Dana 60 rear w/4.88 gears & strange axles. Morroso electric water pump & electric fan. 750 pro form carb. headman headers (2 sets part # 75141 on the car and part # 75131 for W-2 style heads) electric fuel pump and 10 and 5 gallon fuel cell (10 is on the car) trans is 727 w/reverse manual valve body and 4000 stall converter. Car has a line lock, 6 point cage, frame connectors, and drive shaft hoop. Wheels are center lines and 28x11.50 rear tire. Have other gear sets to go with the car. The car is a little rowdy but could easily be put back on the street or stay a track car. [ame="http://youtu.be/K8tjV9lx-6U"]Pulling into the driveway[/ame] [ame="http://youtu.be/bIU8nhwUmus"]Duster at the track[/ame]
