[SOLD] 1973 Plymouth Duster Drag Car
73Duster
Northwest, Ohio
Up for sale is my 1973 Plymouth Duster Bracket Car.
It has a 360 C.I. block bored .030 over, 11.7 Comp. Ratio, Ross Dome Top Pistons, Eagle I-Beam Rods, Cast Crank, MP Ported Swirl Port Heads (P4876180), MP Purple Shaft .508 (P4120233), MP SFI Dampener (P5249692), Indy 1.6 Ratio Adj. Rockers & Shafts, Holley Strip Dom. Intake, Holley 750 DP, HV Oil Pump, 8qt. Oil Pan, Hooker Headers.
727 w/A&A Trans-Brake, Billet Steel Drum, 8" Coan Converter, CSI Trans Shield, Plus more
8.75 489 Housing, Strange Axles & Spool, 4.10 Richmond Gears, SS Springs, Adj. Pinion Snubber, Long Drag Shocks.
26x10x15 MT Slicks, 26x4.5x15 MT ET Fronts
Stock Front Suspension, Frames Tied, .810 Drag Race Torsion Bars, CE 3-way Adj. Front Shocks, Wilwood Front Disc.
MSD 6A w/2-step, Stock Electronic Distributor w/spring kit, Painless 8 switch panel
Fiberglass front bumper, brackets & hood scoop. 6 Point Roll Bar, 5 gal. Fuel Cell, Holley Blue Pump, Hurst Line-Loc, Trunk Mounted Battery.
I have owned this car for 41 years! Started out as a street car and slowly converted over to race only car. It has been a very reliable car. The rear quarters do have some rust and body filler. Still a very solid car. Has original floor pans (no rust), Original glass except for Lexan on doors. I have the original doors, but are the shell only. Belts will need re-certified. Car has run a best of 10.86 @ 121 mph in 1/4 mile. Located in Toledo, Ohio. Asking $12,000 or will consider REASONABLE offers. PM for more Details and Photos. Have clear Ohio title in my name.
View attachment 1715980636 View attachment 1715980639 View attachment 1715980640 View attachment 1715980642 View attachment 1715980643 View attachment 1715980644 View attachment 1715980645
