[FOR SALE] 1974 318 La-250.00$ obo
Joe Bisinger
Livonia
Rating - 0%
0   0   0
Selling 1974 318 La engine. Painted Chrysler red. 318 engine were painted Chrysler red from 1962 to 1969. You get from the carb to the oil pan. All that missing is the valve cover gasket and intake manifold gaskets and bolts. Will trade for small block transmission. Thank you and have a very nice day
Joe,
Where is Livonia? When did it last run? What are the block, head and intake casting numbers? Have you done a static compression check? I don't see a water pump shaft.
Thanks, Richard
904 lock up transmission I'm not 100% on the mileage somewhere around 100k I'm in va tho that is a long ways apart
