Industrial 440 set up to run on propane. This was on an emergency Pump at a water plant. I don’t know how much it has been run over the years. It is extremely clean inside. I have been told these are low compression engines and you have to change the cam as they are set up to run a constant speed. It is a great start for a project.
$950.00 firm. Pick up in Atlanta Ga.
